Hi all,
I will first say the problem I am having is on my very first PC build. I am new at building but very hardware literate. I was so happy that after weeks of waiting for parts and years of waiting for the right price, my dream budget build came to be manifest. But now it simply just won't work.
Here's the problem:
When I turn on the power switch (or short pwr pins while breadboarded) all I get is the PSU, CPU, and GPU (if plugged in, at this point I'm just trying to boot integrated) fans to spin for a second or two then suddenly stop. About 3-5 seconds they spin again. The fans keep going through this cycle and I can hear a faint steady clicking sound (not sure which component). No screen, no beep, no BIOS flash. Nothing but the fans. I have googled and read every "can't boot my pc" article I think I can find, but can't quite find anything that matches my problem 100%.
I have gone through Toms recommended boot failure suggestions and still dead.
MY specs:
CPU:
Intel Core i3-550 Clarkdale 3.2GHz LGA 1156 73W Dual-Core Desktop Processor Intel HD Graphics BX80616I3550
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115065
MOBO:
GIGABYTE GA-H55M-S2V LGA 1156 Intel H55 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128457
MEMORY:
ADATA XPG Gaming Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AX3U1600GB2G9-2G
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211409
GPU:
ASUS EAH6770/DI/1GD5 Radeon HD 6770 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121474
PSU:
CORSAIR Builder Series CX430 V2 (CMPSU-430CXV2) 430W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
OPTICAL:
LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS124-04 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
HDD:
Seagate Barracuda ST250DM000 250GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148765
Please help me. The closest problem that sounded like mine turned out the guy had a DOA CPU. I hate that to be the case, but I'll take all the help I can get.
Here's the problem:
MY specs:
CPU:
MOBO:
MEMORY:
GPU:
PSU:
OPTICAL:
HDD:
