NZXT PHANTOM usb 3.0 front panel connection
Hi guys,
So I'm not sure if this should be in motherboards or cases so I apologize in advance if I'm wrong. So I just bought a NZXT phantom case. I have a MSI z68 G43 motherboard. Since the phantom now comes with usb 3.0 front panel connection, it has a blue plug for the motherboard. It has a usb sign and says SS below it. I don't know how I would connect it to my motherboard. This is my first build and it will be done once I can find this one connection so please help me out.
6 answers Last reply
More about nzxt phantom front panel connection
  1. is this your motherboard?
    http://www.msi.com/product/mb/Z68A-G43--B3-.html
    if so it doesnt seem to have a usb 3.0 motherboard header--only rear usb 3.0
    to use the front usb you would need to use an adaptor and run the cable out the case to the rear usb 3.0
  2. actually I have this
    http://www.msi.com/product/mb/Z68A-G43--G3-.html
    but it is probably very similar. So can you recommend a type of cable I would need as I really don't understand how this would work. Also are there any adapters I could use so I could go straight to my motherboard?
  3. yeah still no usb 3.0 motherboard header
    need something like this
    then usb 3.0 cable
    no adaptor to let you do it to motherboard as they are only usb 2.0 on it
    edit--not letting me paste links correctly--try this one
    http://www.amazon.co.uk/dp/B0037ECAQ8/ref=asc_df_B0037ECAQ88259049?smid=A1ZF5D2D5BXT77&tag=googlecouk06-21&linkCode=asn&creative=22218&creativeASIN=B0037ECAQ8
    and this one
    http://www.coolermaster.com/product.php?product_id=6791
  4. OK thanks. Would I plug both plugs into the motherboard or just one? Again, thanks for the help.
  5. sorry about the links--dont know why some wont work
    the usb cable i linked is too long--you probably need about 2 feet depending on your case
    the y adaptor plugs onto your usb 3.0 connector from the case front--leaving 2 usb connectors--the usb 3.0 cable
    connects to those then goes out the back of the case and plug in to the usb 3.0 ports on the rear of the motherboard
    not ideal but if you really need to use the front usb 3.0 then necessary or a new motherboard with the usb 3.0 header
  6. could also put in a bay device
    http://www.overclockers.co.uk/showproduct.php?prodid=CA-198-SV
    also comes in black
Power Supplies Connection Front Panel Motherboards Components
