Hey, I have a question! I’m building a computer and this will be the first time I have done it on my own... and I’m wondering if I matched up all the parts correctly. Could you help me make sure it’s okay and that I’m not forgetting anything? Oh, and I also have a couple other questions while I’m at it. Are liquid CPU coolers easy to install or should I stick with fans? I plan on buying a second GPU to SLI later on down the road (hence the 1000W PSU), but does it have to be the exact same model? I'll primarily be using this computer for gaming. Thanks in advance.
Rosewill THOR V2 Full-Tower Case
Intel i5-2500K 3.3 Ghz Quad-Core CPU
EVGA Superclocked GTX 560 Ti 1GB
G. SKILL Ripjaws 8GB (2x4GB) DDR3 Ram
Rosewill 1000W PSU
ASROCK Z68 Extreme3 Gen 3 1155 Motherboard
Seagate Barracuda 1TB 7200 RPM HDD
ASUS 24x DVD Burner
ASUS Xonar DG 5.1 Channel SC
Cooler Master V6 GT RR-V6GT 120MM CPU Cooler
(or could I use the… instead?) Corsair H80 Liquid CPU Cooler
Rosewill 1000W PSU
ASUS 24x DVD Burner
