Solved
Dual radiators and dual pumps from a corsair H50 water cooler
  • Water Cooling
  • Cooling
  • Corsair
  • Components
Last response: in Components
June 11, 2012 1:15:09 AM
Hello,i just wanted to get some adice from you experts and enthusiasts from expreiances and knowlede about water cooling, in this case i have 2 pumps and 2 radiators that came from a corsair h50 water cooling kit and basically wanted to know if i could and would be safe to run both radiators and both pumps within the same loop EX: ----RAD----PUMP----RAD---- ___________________PUMP(ON CPU)
More about : dual radiators dual pumps corsair h50 water cooler
June 11, 2012 1:20:40 AM
That doesn't make sense, there is only one pump and one radiator in the H50.
m
l
June 11, 2012 3:09:06 AM
i know what im saying is that i have 2 sets
m
l
June 11, 2012 3:16:20 AM
You can't have two of them on each other?
m
l
June 11, 2012 3:29:02 AM
im just using the extra pump for more push or flow of the water thrugh both rads
m
l
June 11, 2012 3:33:41 AM
Aside from the fact that they're not meant to be disassembled and reassembled period, I suppose that could work, but I'm not sure that's possible.
Why not just go for a H80 or H100? Or better yet, a custom kit from XSPC.
m
l
June 11, 2012 3:43:59 AM
well yea i know they arnt supposed to be dissasembled just was on a budget with what i thought was a budget idea if you get what im saying, could you point me in the right direction for watercooling systems
my setup right now is :AMD-1090T 3.2(O/C-4.0)
NVIDIA GTX560 Ti by built and designed by nvidia
(msi 890gxm-g65-mATX) upgrading to (msi 990fxa-gd80v2)
8gb of kingston 1333 hyperx blu memory 4sticks x 2gb(ea)
460watt coolermaster psu
did i miss any thing you need to know
m
l
June 11, 2012 3:50:11 AM
That's more amuffin's area of expertise than mine really. I know enough to know which closed loop cooler is better, but when it comes to custom stuff, that's totally out of my league.
A H100 or Antec Kuhler H2O 920 are probably the best on the closed loop side (although expensive enough that it makes more sense to go custom, from what I've seen).
m
l
June 11, 2012 3:57:56 AM
i i would like to lean more into the custom side for the reason of costomization and i think would be better but the closed loops are also good to for almost no maintenance but i do appreciate the help you have given me, hopefullt amiffin can give me information and advice in his area of expertise
m
l
June 11, 2012 6:22:02 AM
Read this
Post here
m
l
Best solution
June 11, 2012 9:50:43 AM
certainly possible to disassemble and mod them
if you already have them rather than buy a custom setup
maybe this will give you some ideas
http://www.overclock.net/t/647943/guide-h50-replace-tub...
June 11, 2012 9:04:07 PM
i like this ive seen youtube video before but could never find the owner or the instructions till now to do it thanks alot for this info i have my plans to do this set up when my extra pump and rad comin on thursday
m
l
June 18, 2012 6:02:28 AM
Best answer selected by ROCK40PS3.
m
l
