Closed Solved
Will these parts work ok together?
10 answers Last reply Best Answer
More about will parts work together
  1. not really ok - you can do a lot better with the mobo/CPU for $220... PSU too powerful for 1 x 6850 and best to go with a different brand... RAM you're putting only 1 chip of 4gb, rather than 2x2gb...
    fill this out:
    http://www.tomshardware.com/forum/261222-31-build-advice
  2. Sorry I wasn't more specific about what type of build I want.
    Approximate Purchase Date: The sooner the better.
    Budget Range: I don't want to spend over $750
    System Usage from Most to Least Important: Games, web browsing.
    Parts Not Required:Mouse, keyboard, or monitor.
    Preferred Website(s) for Parts: Newegg, Amazon, Tigerdirect.
    Country: USA
    Parts Preferences: Probably AMD cpu.
    Overclocking: Most likely not.
    SLI or Crossfire: Probably won't.
    Additional Comments: Yeah the only stuff I bought is the case and disk drive.
    I wouldn't mind any recommendations either.
  3. If you are spending that much on a CPU, switch over to the Intel 2100/2120. PSU should be ok but if you want to drop down to a 500W you should be fine there as well. Seeing as that PSU is ~$60 I'm not sure how much you could save.
  4. ok, without the parts you already have -
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371030
    - Antec NEO ECO 520C 520W: $60
    http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
    - Microsoft Windows 7 Home Premium SP1 64-bit: $100
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767
    - Seagate Barracuda ST500DM002 500GB 7200 RPM: $85
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131783
    - ASUS P8H67-V (REV 3.0) LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0: $105
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115092
    - Intel Core i3-2130 Sandy Bridge 3.4GHz: $150
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231426
    - G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333: $40
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102948
    - SAPPHIRE 100314-3L Radeon HD 6870 1GB: $170
    TOTAL: $710
    great quality system with good parts, better video card.. and that Intel CPU will smoke any AMD one, especially for gaming, at that price point
  5. If you want AMD CPU, the FX ones are a horrible choice. Stick with Phenom.
  6. Best answer
    or instead of the 6870.. you can get this and just stay within budget:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814125401
    - GIGABYTE GV-N560UD-1G GeForce GTX 560 Ti (Fermi) 1GB: $210
    new total with this card instead of the 6870: $750
    TOTAL: $710
    Very quality build. I agree that this would be the better way to go for the OP, but I would disagree with you on one thing. The processor. It is a complete waste to spend an extra $22 for a 100mhz clock increase and better integrated graphics when he is using a dedicated GPU.
    I would pick the i3-2120 over the i3-2130 in this situation and use the difference to upgrade the board.
    I3-2120 = http://www.newegg.com/Product/Product.aspx?Item=N82E16819115077 - 127.99
    Gigabyte GA-Z68A-D3H-B3 = http://www.newegg.com/Product/Product.aspx?Item=N82E16813128502 - 129.99
    This will give you a nearly identical processor to the 2130 and will give you a much more upgradable board. The board is IVY compatable and is PCIe 3.0 compatable as well. Makes any future upgrades well worth the consideration.
  8. Best answer selected by Crunchy32.
  9. Thanks for all the replies, I will probably be going with wasupmike's recommendation
    except for maybe the CPU and perhaps the MOBO. I will probably go with the i3-2120
    because of my budget. I now know this a very reliable computer forum to consult for all my future questions.
  10. This topic has been closed by Mousemonkey
New Build Cases Disk Drive Systems Product
