Hi everyone, I've decided to do a major overhaul upgrade for my PC, I was wondering if the products I plan on purchasing are good choices, I already have a decent graphics card and an 800 watts Corsair PSU which is why I won't bother buying a new one of those parts. Not sure if the sound card is really necessary, is it worth buying? I plan on using the PC as a gaming PC.
The products I plan on buying are, just wanna know if there are any products better than the one's I've picked, finally are there any fans you would recommend? Thanks for the help.
http://www.amazon.co.uk/Asus-P8Z68-V-PRO-GEN3-Motherboard/dp/B005T3TLM6/ref=sr_1_34?s=computers&ie=UTF8&qid=1327247884&sr=1-34
http://www.amazon.co.uk/Intel-Sandybridge-i5-2500K-Quad-Core-Processor/dp/B004FA8NX2/ref=sr_1_2?s=computers&ie=UTF8&qid=1327246520&sr=1-2
http://www.amazon.co.uk/Creative-30SB10420000-Sound-Blaster-Xtreme/dp/B001UJM5FI/ref=sr_1_1?s=computers&ie=UTF8&qid=1330037467&sr=1-1
http://www.amazon.co.uk/Logitech-Z506-Surround-Sound-Speakers/dp/B003WJR482/ref=dp_ob_title_ce
http://www.amazon.co.uk/Corsair-CMZ8GX3M2A1600C9-1600MHz-Vengeance-Memory/dp/B004CRSM4I/ref=sr_1_1?s=computers&ie=UTF8&qid=1330038206&sr=1-1
http://www.amazon.co.uk/LG-DM2780D-inch-Cinema-Monitor/dp/B00606JKRC/ref=sr_1_1?s=computers&ie=UTF8&qid=1330038613&sr=1-1
http://www.amazon.co.uk/Sharkoon-ATX-Midi-Tower-Case/dp/B004REHPD0/ref=sr_1_17?s=computers&ie=UTF8&qid=1330037358&sr=1-17
