Closed
GTX 460 SLI power supply
December 25, 2011 5:04:29 PM
Can I buy another GTX 460 and SLI them with this setup:
Athlon II X4
2 Cold Cathodes
2 140mm fans
3 120mm LED fans
1 120mm fan
Fan controller
NO DVD/CD
IDE hard drive and SATA hard drive
870-g45 motherboard (using SLI-hack)
With this power supply:
AZZA Dynamo 650w:
Type
ATX 12V Ver 2.2
Maximum Power
650W
Fans
1 x 140mm Blue LED Fan
PFC
No
Main Connector
20+4Pin
+12V Rails
PCI-Express Connector
1 x 6-Pin, 1 x 6+2-Pin
SATA Power Connector
4
SLI
Ready
CrossFire
Ready
Efficiency
>78%
Over Voltage Protection
Yes
Overload Protection
Yes
Input Voltage
115V/220V
Input Frequency Range
50/60 Hz
Input Current
10.7A/6.2A
Output
+3.3V@24A, +5V@32A, +12V1@21A, +12V2@22A, -12V@0.6A, +5VSB@2.0A
MTBF
100,000 hrs at 25°C, Full Load
Dimensions
5.9" x 3.25" x 6.4"
Features
Connectors
1 x 20+4 Pin Motherboard
1 x 8(4+4)Pin ATX Connector
1 x SLI(6pin & 6 +2pin) Connector
4 x SATA Connector
6 x IDE Connector
1 x Floppy Connector
I understand it may not be optimal, but will it run?
also It only came with 2 SLI connectors and the cards call for 4. Am I safe using 2 6pins and 2 molex->6 pins.
The combined wattage on the 12v rails is 456w(38A) according to the power supply box.
a b U Graphics card
December 25, 2011 5:45:27 PM
ahtlon hmmm, what model is it?
Athlon are not good option for to sli gtx 460...it would make a bottleneck of your cards.
Score
December 25, 2011 5:47:04 PM
Model 640 OC'd to 3.5Ghz.
I realize that its budget and I am on a budget but the next thing I would upgrade would be CPU.
Score
a b U Graphics card
December 25, 2011 5:51:29 PM
after checking it out on newegg that power supply only has a combined 38 Amps on 12v rail , I dont think that's sufficient (or safe) for dual 460s.
Have you tried overclocking the 460? Those things can be increased in performance by almost 30% , it's nuts
Score
December 25, 2011 5:53:12 PM
Yeah I did overclock it and got 15-20% more out of it but its still not near enough to play battlefield 3 on ultra.
Score
a b U Graphics card
December 25, 2011 6:15:08 PM
this is what you should do for bf3 that I do for my 6850, put everything ultra, but turn shadows to high. At least for the single player it's fine, and literally no difference in picture. I have a 2500k tho, but even with 4xaa it was playable like this with high shadows and everything else ultra.
I couldnt tell the difference between High vs ultra shadows, there's really no point to spend money on another 460 with doubts whether or not it would work just to enable it...lol just enjoy the game.
Score
December 25, 2011 6:18:49 PM
Well the problem is after this current patch I can't even play the game with everything off/low at 60fps constant.
I was hoping to fix that with the gtx 460 SLI
Score
a b U Graphics card
December 25, 2011 6:23:01 PM
well the 460 is definitely enough to play with everything off/low at 60fps, the problem lies elsewhere for sure. Try reinstalling or downloading newest nvidia drivers from their site. 460 SLI won't help you here since the GPU isn't the bottleneck at such low settings.
Score
December 25, 2011 6:33:42 PM
It was before the patch happened but now I'm seeing such low GPU usage its ridiculous.
I'm on 290.53 but I have changed it many times with the same results.
Score
Best solution
a b U Graphics card
a b ) Power supply
December 25, 2011 6:34:34 PM
I wouldn't trust that cheap power supply with the money you have into your other components that it can destroy.
Although these are more expensive I would trust them.
Only difference is that the one is modular.
a b U Graphics card
December 25, 2011 6:53:03 PM
Bro you have low gpu usage = there is no bottleneck on the gtx 460, if you buy 2 gtx 580s it still wouldnt matter, your problem lies in a different component or if you're saying it was fine before then it's a software/driver/patch problem. Reinstall the game maybe or google it, im sure other people will have similar problems.
Score
December 25, 2011 7:02:57 PM
other people do have problems like it, I'm just not sure if it will ever get fixed as DICE is horrible at fixing stuff atm.
Score
a b U Graphics card
December 25, 2011 7:03:51 PM
lol well regardless dont go buying another 460... just play some skyrim before you take an arrow to the knee :D
Score
December 25, 2011 7:05:35 PM
haha alright. I might just wait till new video cards come out and buy a whole new PSU Mobo and CPU.
Score
December 31, 2011 11:00:51 PM
Best answer selected by Elektrey.
Score
