Best power supply
budget: 270
gpu/cpu amd 7970 amd bulldozer 8120 overclocked
Now i really want a good one im thinking either the cooler master silent pro gold or the corsair hx-1050
the cooler master is 228 and the corsair is 265
(Im in Australia these are the prices)
7 answers Last reply
More about best power supply
  1. If you don't Crossfire a 600W-650W PSU in more than enough. If you have in plan 2 video cards buy Corsair.
  2. Hm.. i just a Antec high current gamer 900w for only 150 thats much cheaper thoughts>
  3. If you want something really good in quality. Go with either Corsair AX series or XFX ProSeries. These two PSU are some of the best quality PSU you can get.
    Whats the difference with corsair hx and ax
  5. Corsair AX is 80+ gold certified and HX is 80+ certified. Both have 7 years warranty.
  6. Corsair AX series, Antec High Current Professional, Seasonic X series, Coolermaster Silent Hybrid Professional all 80 Gold certified.
  7. I've recently built a rig using the AX850, absolutely brilliant! Super quiet and the modular cables made installing very easy indeed!
New Build Cooler Master Power Supplies AMD Corsair Systems
