CPU - 2500k from local Microcenter $40 Cheaper then NewEgg
MoBo - Asrock Professional 7 Gen 3 http://www.newegg.com/Product/Product.aspx?Item=N82E16813157269
RAM - G.Skill RipJaw 2133 8gig http://www.newegg.com/Product/Product.aspx?Item=N82E16820231476
PSU - Corsair 850w http://www.newegg.com/Product/Product.aspx?Item=N82E16817139015
SSD - Samsung 830 128gig. http://www.newegg.com/Product/Product.aspx?Item=N82E16820147137
GFX - Sapphire 7970 http://www.newegg.com/Product/Product.aspx?Item=N82E16814102961
CASE - Corsair 650D http://www.newegg.com/Product/Product.aspx?Item=N82E16814102961
COOLER - Corsair H100 http://www.newegg.com/Product/Product.aspx?Item=N82E16835181017
Things I've considered...
1. The Mobo is a little more then I wanted to spend, but I wanted a GOOD overclocker.
2. The CPU Cooler is more then I wanted to spend but I wanted to OC, and I want the case to look Clean.
3. THE RAM IS BLUE!!! UGGGG! I'll have a missmatch looking set of parts.. I may replace the heatspreaders with aftermarket later to make it match.
