I would like to get away from my radeon hd 4200 integrated card in my hp pavilion p6823w so ive been looking at the 5570 because ive been looking for a card that would run alright on a 250watt psu. Ive been doing some research and i found that this card should do fine on 250watt psu's.
So ive knocked down my choices to these two,
the XFX Radeon HD 5570 ($34.99)
http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=604817&CatId=7005
the Powercolor Radeon HD 5570 ($54.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131342
Why is the XFX version cheaper than the Powercolor one? Only difference i see is the brand.
Which one should i go with? should i spend the extra $20 for the powercolor?
