Solved
PC Connected to Surround Sound - Quality Sucks?
Last response: in Components
Currently, I have my PC connected to my 21" LCD tv via HDMI cord. This tv is connected to my full surround sound system. The sound is very bad quality when doing anything like listening to music. I think it is my setup: I have PC connected to tv with HDMI, the only audio output from my tv is headphones so I have a headphone jack split into the red and white av cords. These cords connect to the red/white input on my surround sound system. I sure this is why there is bad sound quality. How to make it better? Im guessing I need direct input from my pc to speakers. How would I do this? Thanks
If you are using it for gaming, it is better to connect your surround sound directly to the 6 channels of motherboard. If your surround sound system have 3.5mm audio input jacks (where the headphone jack go), then it should come with 3 cable connectors that you should plug to 3 audio channel ports in your motherboard ( center/sub, front l/r & rear l/r ).
If your speaker's input jack is only the AV cord type, then you should have at least 3 of the headphone jack split into the red and white av cords. The headphone jacks goes to the motherboard while the av cords go to your speaker.
To clarify, what is your surround system & what is your motherboard brand & model?
Not sure my actual motherboard. it is stock that came woth my Acer Aspire T180. I know for a fact it has those 3 colored plugins: blue, grern, pink. My surround sound has a digital optical input so would it be best to buy a sound card for my pc with a optical output? Thanks
I thought your sound system comes with AV input?
Instead of connecting the headphone jack from the tv output, connect it to the green plug in & see if the sound improves ( but of course it will be only left & right ).
Related ressources
the issue is your connection from TV to receiver. if your mobo does not have an optical out, your best bet would be to get a sound card with one and run the sound directly to the receiver.
Yes I believe my only option is to get a sound card with optical output. The only audio input with 5.1 on my surround sound is Optical in. (Sorry i just realized this) However the sound card you gave me the link for was for newegg.com and since I am Canadian, I can not find it on newegg.ca. What is your suggestion for me to get a cheap optical sound card? I can shop on either ebay, or newegg, or anything else with a cheap price. Thanks
$18 after rebate on tigerdirect.ca
nightshift also linked the ncix site with the same card
http://www.tigerdirect.ca/applications/SearchTools/item...
Well, it sounds like you are going HDMI to the TV, then using the headphone out from the TV to the receiver. Because TV's have HORRID conversions from digital to analog, you are going to take a corresponding quality hit.
What inputs do you have on the surround system?
ct1615 said:
it will do the job
OK. I will buy this card then. When I get it what do I need to do? Just plug it in and install the drivers? Or do I have to disable some onboard audio or something. I heard someone talking about this. Thanks
Best solution
go into your BIOS and disable onboard audio. usually for music & video playback you won't have an issue. some games may have an issue. I know WoW has a bug with creative sounds cards (pretty sure that rocketfish is a re-branded creative) and on-board mobo audio being on. even if you don't disable the on-board audio its not likely you will see any issue, its more of a "might as well do it" thing.
install the card
win7 will most likely install the drivers for you
you can install any other software from the driver CD you want
with win xp, just install the drivers after you boot up
Ask the community
