What should fix me? I just upgraded my GPU to a SAPPHIRE AMD Radeon HD 6870 1GB GDDR5 PCIE
My Specs:
Biostar N68S+ Motherboard - GeForce 7025, Socket AM2+
AMD Phenom X4 9600B 2.3GHz
2 x Corsair 2048MB PC6400 DDR2
Thermaltake 600W PS
Kind of a budget system I built a bit ago. Had a GTS 250 in there and was getting decent FPS in games but decided to upgrade trying for the Ultra graphics. Threw the 6870 in and it got worse. Assuming I'm bottlenecking. If I'm on a budget should a faster Phenom II X4 fix me? This is also my first Radeon so not sure if there are any settings I should look into. I do have the latest driver for the card. Im getting like 15 - 25 in SWTOR on High settings @ 1920 x 1080.
I asked a similar question about this earlier and thank those that gave opinions but I guess now I'm looking for advice on what to upgrade. Or at least confirmation that it is probably my CPU killin the card. The motherboard supports Phenom II.
Thanks
My Specs:
Thermaltake 600W PS
Thanks
