I was considering Silverstone Grandia GD-05B http://www.newegg.com/Product/Product.aspx?Item=N82E16811163166
Concerned that CPU cooler won't fit. I have a stock Dell cooler on Q9400.
I wen to http://www.silverstonetek.com/product.php?pid=241&area=en where it says:
Limitation of CPU cooler 70mm (remove ODD if you want install up to 120mm)
Obviously I will not remove optical drive--that is 50% of the reason for this case for me.
Does anyone know if 70mm refers the height of the CPU cooler?
