I built my PC about a year ago and have allwaya had a few minor problems with it (Occasional freezing, USB ports not working etc) and now i have a really bad problem. The computer will randomly lock-up while it is on, no matter what I am doing. It used to do this occasionally but it stopped after a while and it had been running quite well. Now it will freeze usually every hour or so and sometimes it will even do it on the 'Welcome' screen.
I originally thought it was a ram problem so i ran Memtest (The windows one) and it froze at 21% (Was there for 4 hours) so i thought it was a memory issue. I would have used Memtest86+ but I did not have internet access to download it. So the next day I went to a friends place with internet to purchase some replacement ram (another reason for not doing more testing is that the ram i had was not from a well known reputable brand) So I bought an 8GB pack or Corsair Vengeance ram (2x4GB, 1600Mhz, 9-9-9-24) from eBay.
I installed this in my PC thinking that it would solve the problem and it seemed to work fine for about 4 hours, and than it froze. It than froze roughly every hour after that.
I have tried this: Resetting BIOS to both 'Fail-safe' and 'Optimized' Defaults, Replacing RAM, Re-seating RAM, Checking everything is connected properly, removing any unnecessary components, Re-installing windows (twice), Using Memtest86+ (After replacing ram) and there are no errors and it does not freeze.
Another thing that bothers me is that the ram is only running at 1333Mhz, even after resetting the BIOS and the only way to make it run at the 600 it is meant to is by setting it to 'turbo' mode, which also over-clocks my CPU to 4Ghz (Which sort of scares me ). I have tried many BIOS settings but to no avail, it continues to freeze.
Another (Possibly unrelated?) issue is that most of my USB ports do not work properly and require a restart of the computer to register anything that is connected, but the USB 3.0 ports and the eSATA/USB ports work fine. I originally thought this was a PSU issue so i bought a new PSU.
Here are my system specs:
Motherboard: GIGABYTE P55A-UD6 Rev. 1
CPU: Intel i5 660 (3.33Ghz)
GPU: ATI Radeon HD 5750
RAM: Corsair Vengeance 8GB (2x4GB, 1600Mhz, 9-9-9-24) (Was Team xTream 6GB (3x2GB) 2000Mhz (Always ran at 1333))
HDD: WD Caviar Black 1TB (Was originally a WD Enterprise storage drive of some kind)
PSU: Corsair HX750W (Was GIGABYTE 550W cheap PSU)
OS: Windows 7 Ultimate 64-Bit SP1 (To test if the disk is corrupted I have tried my friends Home premium 64-Bit, same result)
I would like to know if there is anyway of solving this or is my MB/CPU 'stuffed'? DO i need to set different voltages as some other threads suggested? There are so many BIOS settings on this board and the instruction booklet looks like it has been translated from Chinese with Google translate, so it doesn't really help me at all.
The crashes freeze the mouse, keyboard, screen, sound everything. The sound just locks up in a loop if anything is playing (Plays pretty much the not it froze on over and over)
It will not crash at all if I just leave it alone, but it will crash if i am using it even if I am just playing music, browsing the web or just moving files around. It does crash more often while running games, and crashes mostly when running Minecraft. Temperature is NOT an issue with my CPU virtually never getting above 55C (I have it set to warn me if it gets to 60C) and my graphics card never gets above 65C. I have good ventilation and there is very little dust in my case, as i clean it often. I had made no hardware or software changes when the crashes started (They started while I was playing borderlands multiplayer)
Hope that someone can help with this because it makes my computer virtually unusable because I lose everything I am working on when it crashes.
I think i included everything i need,
Kai Waugh
Kai Waugh
