Build Problem !!!HELP!!!
  • Power Supplies
  • BIOS
  • Build
  • Components
Last response: in Components
June 12, 2012 11:55:22 PM
Hello everyone
I am finally done with my build
I have a big problem though
Every time i turn it on to proceed with the bios
it turns back off.
It goes on shows the bios screen and turns back off.
When i press DEL to check bios nothing happens and it turns off
and on and back off on its own.
Does anyone know what this might be?
More about : build problem
a b ) Power supply
June 12, 2012 11:57:04 PM
Since you don't mention your full specs, I'll just suggest using only one RAM stick and seeing if it posts.
m
l
June 13, 2012 12:04:54 AM
Specs
Motherboard:Gigabyte G1 Sniper2
CPU: i7 3770 Ivy Bridge
Memory: 4x8 vengeance memory
Power Supply: 1000 W
Video Card: Asus TX 590
When i turn on the computer all the fans spin fine
while the bios screen its showing.
Then all shuts down and restarts again in continuation
m
l
a b ) Power supply
June 13, 2012 12:07:52 AM
Definitely check all your connections and try the single RAM stick out. Does your motherboard beep at all?
m
l
June 13, 2012 12:13:24 AM
actually when i turn it on it shows the bios then it turns off and back on and stays on without displaying anything on the screen
m
l
a b ) Power supply
June 13, 2012 12:19:51 AM
That's a really high wattage PSU for your system but did you make sure to connect the power supply to the graphics card?
m
l
June 13, 2012 12:22:09 AM
yes i did that
and im sorry it turns on and off in continuation
m
l
a b ) Power supply
June 13, 2012 12:29:01 AM
Can you remove the graphics card and try to boot up the computer using the integrated graphics?
m
l
June 13, 2012 12:33:48 AM
ok so leave one ram stick in and remove grphics card?
BTW everyting runs when i turn it on it just shuts back off after being on bios for a few seconds.
Then it keeps doing this not letting me into the bios only showing bios screen with the gigabyte logo
m
l
July 14, 2012 3:38:19 PM
Hey thanks for trying to help me out enigma.
I have already figured out what the issue was and got it fixed.
I will be doing a post on it since this might be a problem for a lot of people.
m
l
