Problem with Sound
Last response: in Systems
Homebuilt system Master
Okay, bit of an interesting quirk. I have a custom build computer, the built in sound card had some feedback issues on the speaks. From what I gathered, this can be typical of on-board sound cards, so thinking I was clever, I installed the SoundBlaster Live! card from my old Dell 8200 in it, installed http://kxproject.lugosoft.com/ these drivers which were supposed to work with the antiquated card on Windows 7. Boot it up, no change in the feedback, AND I now have no sound coming from either the SB Live card or the motherboard on-board. Racking my brain on this, I've uninstalled the KX drivers, and still no go on the sound from the on-board ports. When I use the test feature it shows sound is playing but nothing is coming out of the speakers but that dastardly fan noises I was attempting to get rid of by installing the SB Live in the first place.
Any thoughts?
System Config:
-Phenom II 975 Black Edition
-Gigabyte GA-990FXA-UD5
-16GB Corsair Vengence (2x8GB)
-Zotac 550 Ti Amp! Edition (NVIDIA)
-750 Watt power supply
More about : problem sound
NVM. I should have learned by now, the simplest explanation is usually the correct one. The speakers were just crappy. Invested in a 25 dollar set from Walmart and no problem.
Ask the community
