Solved
Power Supply Recommendation
First build and i wanted to know if anyone had a good recommendation for a power supply (700w or 750w) that is modular.
12 answers Last reply Best Answer
More about power supply recommendation
  1. how much are you willing to pay for quality
  2. What are your system specs? Budget?
  3. It's a great PSU; it's overkill unless you're doing SLI or Crossfire. A good quality 500-550W PSU is sufficient for almost any single-GPU system; that's why i asked about your system specs.
  4. i5 3570k
    GIGABYTE GA-Z77X-UD5H LGA 1155 Intel Z77
    16gb Corsair Vengeance RAM 1600
    EVGA SuperClocked 012-P3-1573-KR GeForce GTX 570 HD
    Seagate Barracuda ST1000DM003 1TB 7200 RPM
    I think what will happen is down the road when my card becomes outdated i will SLI
    and i will do some OC down the road also
  5. huntx23 said:
    i5 3570k
    A system with a single GTX 570 requires a 600W PSU with 40A on the 12V rails and two 6-pin PCIe power connectors. Two of them running in SLI mode requires a 850W PSU with at least 58A on the 12V rails and four 6-pin PCIe power connectors. These requirements are for factory, stock-clocked GTX 570s.
    The TX750 has 62A on the 12V rails and four 6+2 pin PCIe power connectors. It is sufficient for a system running two GTX 570s in SLI mode. Because your GPUs are factory OCed I would do any further OCs to the GPUs in small increments and try to stay at stock Vcore for CPU OCs; small increments with stress-testing for stability on each incremental increase.
    If you wait too long, then you may have an issue finding another GTX 570 for your SLI. Nvidia will start to phase out the 570s now that the 600 series GPUs are on the street. On the bright side, as Nvidia and retailers clear stock to make room for the new GPUs there will definitely be some good deals on these cards. Just be careful how long you wait...
  6. so in that case should i spend the extra dough and get a 900w supply just so i have something that will last me when i decide to upgrade/sli
  7. Best answer
    If you know that you're getting a second superclock GTX 570 and want to do some additional OC to both the GPUs and CPU, then I would consider the TX850 for more reserve 12V capacity.
  8. ok i think thats what i will do because after rebate its not much more money and it will last me a long time. thanks so much for the help and the info
  9. Best answer selected by huntx23.
  10. Glad I could help - enjoy your new PSU!
  11. will do!
Power Supplies Build Components Product
