Power Supply Problems
Last response: in Systems
Yes you need to connect to the MB first because the case have a power switch cable to connect to MB and from MB sent signal to the power supply to run....
There has another method to make the power supply run without connect to MB ... we can test it be use a paper clip and connect to 2 pin on the 24 pin ... But you don't need to do that...
Just connect to MB first...
Ask the community
