Okay, after weeks of head scratching and thinking, I've finally picked my parts for the Gaming PC I'm building. They are as follows:
i3 2105 ($135)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115090
Motherboard ($55)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157241&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=7w4njyovkrgl
4GB RAM ($20)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231310&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=15ox2697qijz8
500 GB HDD ($90)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=1m03r8o2rn1xs
22x DVD Burner ($15)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151244&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=1367uxl9w9lt5
600 Watt PSU ($70)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=vjun79ks0dxi
GTX 560 Ti ($180)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7210574&CatId=3669
Now, for a case, i just want a cool looking case from newegg with good airflow that can fit a GTX 560 Ti, and is under $40. I know that narrows my choices a lot, but there are a couple ones i'm liking:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156223
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119246
http://www.newegg.com/Product/Product.aspx?Item=N82E16811517015
http://www.newegg.com/Product/Product.aspx?Item=N82E16811121096
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156237
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147159
They all look really cool, and im really liking the raidmax and cooler master ones, but my number one factor is this: can it fit big graphics cards? if it can, then im also looking for a good cooling and airflow. and finally, some cool internal lighting would help. please help me decide on a case.
also, if there is anything else i need to look out for, please inform me. any other suggestions would also be useful. thank you very much.
i3 2105 ($135)
Motherboard ($55)
4GB RAM ($20)
500 GB HDD ($90)
600 Watt PSU ($70)
GTX 560 Ti ($180)
