My asus 5770 cucore temp problem
Hello Guys, What is the normal temp for a asus 5770? While playing games i got 75-85~C temp readings with 90% fan. My idle temp is 45-50~C. Is this normal?
2 answers Last reply
More about asus 5770 cucore temp problem
  1. Hey man, I had the same problem yesterday with my XFX 5770 and when I played a game it kept crashing. Looked in ccc and my temp was 100 degrees, idle was a 60. I found the problem and just done a google search to help other people, so I found you now ;) Here's the fix:
    Open the graphics card up and remove the heat sink that sits on top of the gpu, the part of the heat sink that is facing the fan builds up a lot of dust, so much so that it blocked almost all the air that the fan is trying to push out. At first when I open the card I thought there wasn't a problem because you couldn't actually see the fins on the heat sink that is facing the fan. I guess you could call this a bad design of the graphics card. Just remove the dust particles. There'll be thermal paste on the gpu and the heat sink, I didn't reapply new paste because I don't have any but it still worked like a charm when I put it all together. Happy New Year!
  2. [quotes=2518469,1,1070905]Hello Guys, What is the normal temp for a asus 5770? While playing games i got 75-85~C temp readings with 90% fan. My idle temp is 45-50~C. Is this normal?[/quotes]
    Edit
    Never mind.
    But temps should be with good air flow ~35c idle and max depending on how high you set the GPU fan speed (higher the better) around 52c-85c. Mine stays at 52c testing with MSIs Kombustor.
Radeon Asus Games Fan Graphics
