Solved
Suggested build for new system
I want a good system that will also last.
Approximate Purchase Date: March 2012
Budget Range: $400 - $500
System Usage from Most to Least Important: Casual Gaming (Skyrim, Future Diablo III, possibly Mass Effect), Internet, Video Streaming, Home office use and for graduate classes, some web design
Parts Not Required: Monitor, speaker system and OS
Preferred Website(s) for Parts: Prefer Newegg but willing to take suggestions from others
Country: Georgia, USA
Parts Preferences: Ones that will last longer
Overclocking: Maybe
SLI or Crossfire: Maybe
Monitor Resolution: 1024x768
Additional Comments: I have an older Sapphire X850XT from a previous system but am unsure if it better to just get a new one?
I was considering buying a barebones kit from Tigerdirect.com but have heard it is better to buy individual components. Would prefer any suggestions you might have for builds over barebone kits.
Suggestions Please.
Regards,
Jason
9 answers Last reply Best Answer
More about suggested build system
  1. If you are going to buy barebones, get it at newegg. You get newer parts from their shellshocker barebones kits, not leftovers. They had both an amd and Intel barebones last week for under $300 each. Both included 500gb hardrives.
  2. Best answer
  3. Just 4 MB RAM versus 8 MB?
  4. I looked at your budget , but for 15$ more change the RAM with this 8GB G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231422
  5. Also, would it be better for me to try and spend a little more to purchase a video card with 256-bits versus one with 128-bit?
  6. If you want to spend alittle more i recommend you 6850.
    SAPPHIRE Radeon HD 6850 1GB 256-bit GDDR5 http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
  7. Will this motherboard and PSU support an i5 or i7 if I decided to spend the extra cash for it or decided to upgrade in the future?
  8. You can change with this CORSAIR Builder Series CX600 V2 600W http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028 50$ after rebates. This will support a CPU upgrade and a more powerfull video card. Is 10$ more than Corsair 500w and the same price after rebates.
  9. Best answer selected by jea0126.
Homebuilt Systems Product
