I'm putting together a new computer, going to use it for gaming. Might over clock my PCU, dunno yet. My system specs are as follows:
CPU - intel i5 2500k
GPU- sapphire radeon 6870 1gb card
Motherboard - asrock z68 pro3 gen3
cd drive - lightscribe 24x dvd r/w
HDD - samsung 500gb 7200rpm
case - nxzt guardian 921 with 3 fans.
I had a rosewill 630w power supply, and my computer was up and running just fine, my first new build. The graphics card wasn't seated properly, so I fixed it, got it set right. Turned the computer on and all my blue leds just flashed and the fans stuttered. Turned it off, unplugged psu from wall, plugged it back in and turned it on. It made a quiet "thud" kind of sound and computer won't turn on anymore. I assume my power supply just died. Do I need a bigger one? I was told my system could get by on a 500w, opinions?
P.S. - The psu dying so uneventfully wouldn't have fried any hardware would it have? As all ways, any help is very appreciated and thank you.
