So I did my first build this week and I'm liking this case so far. This is going to be an audio/video workstation, so I went with a 3770k for processing power and a Hyper 212 EVO for cooling.
I have to say, with a side fan and exhaust fan, as well as the EVO, my temps are very good with this case.
However, since it has 2 case fans and is very ventilated, it's far from quiet, which is bad for me since I'll be audio mixing down the line. I won't be doing any heavy recording, but definitely some low level mixing where the fan noise will be distracting.
So, are their relatively cheap ways to sound dampen this case? I know I can't get the performance I would get out of a $150 case, but I'd just like to improve performance here.
The first thing I'm going to do is swap out the exhaust fan for something much quieter. It works well but it's just too noisy on idle.
Next, I'm assuming the side fan (which is installed on the big panel window) is a problem since the window generates more vibrations on the surface. Not sure if it's worth replacing this as I haven't really investigated how much it adds to my case flow.
I'm going to leave the EVO CPU fan because it seems to be pretty quiet for what it does.
The only other thing I can think of doing is putting some foam on one of the top vents. They are actually optional fan brackets but I have no room for fans, so I was wondering if putting some foam on the vent closest to me would be a good idea since it could hurt temps. Maybe a thin layer?
Again, not looking to pour more than 35-45 bucks into this and not looking for a miracle, just a bit of noise reduction. Do any of these strategies seem worthwhile? And can you recommend a good exhaust fan for the case (in the $20 range)?
