Replacement help.
Razanel
11
So recently my motherboard died and possibly my CPU (will figure that one out tomorrow). I had an i5-2500k and a pz68 asus motherboard. Budget is not really an issue (will have about $350) and I would like to know if I should just replace those parts or get new ones. I do mostly gaming (Civ 5, Diablo 3, BF3, etc.) and a little video stuff (I mention Civ 5 because of how CPU reliant it is). Any help would be appreciated. Thanks for your time!
Check and see if it's just your mobo if it is i recommend just getting new motherboard this is a good one http://www.newegg.com/Product/Product.aspx?Item=N82E16813157264 and if you really want to floss like a big dog gigabyte finally came out with there 4 way board, not a bad price at all http://www.newegg.com/Product/Product.aspx?Item=N82E16813128552 if your mobo and cpu is dead then here is a good combo
MOBO CPU- http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.951181 sli/crossfire MOBO case you like to sli down the road.
