I have a problem here. What happened was I was listening to music, and the iTunes updater popped up, and I figured I hadn't updated in a while, so I may as well do it now. But after the update, I noticed there was something really wrong with my sound. Whenever I try to play a song from Youtube, I get way too much bass, and not enough treble. And the sound just sounds really fuzzy. Same thing happens whenever I play a game. My first thought was that there was something wrong with my headphones, but when I tried them on my laptop, and on my Xbox, the sound is fine. I also tried using my speakers on my desktop, but I got the same issues. But when I listen to a song on iTunes, I don't get these problems, the sound is perfect, just like it was before the update, it's only on any other application that I get the sound problems. The version I updated to was 10.6.3, are there any known bugs with this version that may have caused this problem? And I also looked around control panel to see if I could adjust the audio settings, but I couldn't find anything. The Realtek HD Audio Manager was no help either.
Any help would be much appreciated, thanks!
