Hi guys,
The computer I built for my little brother ran a little hot so I decided to replace the thermal paste seeing I had probably messed up when I built it (because the HSF was really hard to get on so I most likely smeared the preapplied paste too much). Well after applying the paste a first time, it was really bad and I got in the high 80s. After a second attempt, I got high 30's, low 40's on idle and called it a night. The next day, however, my brother started getting high 80's on idle right after booting :/ so I went and redid the thermal paste AGAIN. I feel really unlucky with this right now and my current problem is that after my latest attempt, the PC boots and all the fans turn on, but the mobo doesn't beep and I can't see anything on the screen. I've already tried removing the GPU and RAM and booting it but same problem. I also tried removing the battery and putting it back in but to no avail.
The thermal paste Im using is Arctic Silver 5 and although it may seem I might be using bad form, the HSF has a really annoying design and so it is easy to smear when attempting to lock it in. (The HSF has two thin metal clamps, its the stock cooler that comes with the AMD Phenom II X4 965) It should also be noted that I attempted both the pea drop and spread methods.
My question is, is this a mobo problem? And what are some other methods I can attempt to fix this?
Id really appreciate some help
