I just built this computer, what was my $400 budget-gaming pc turned into a $800 gaming pc.
Specs:
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=23504747
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341016
I have everything in the two links up there ^
Now this is very confusing and hard to explain, so Im going to try my best.
It worked for the first 3 boots on DVI and after doing all the updates/validating my windows it stopped booting. It would POST successfully and I just assumed it didnt boot, I don't have speakers so I never heard any windows startup music. Then one time I had my headphones on and noticed windows loaded, but it didnt display anything on screen. So I grabbed my brothers monitor and bam, it booted up perfectly using DVI on his monitor, then after I boot with his monitor using DVI I can switch to mine using DVI and it works fine, but if I start with my monitor on DVI I cant use DVI it how ever works with VGA.
Now I plugged my monitor into my brothers computer using DVI and it will work on his computer booting on DVI. The monitor appears to work fine, but I just cant boot with my monitor using DVI. What can I do to fix this? I've tried deleting the driver for my monitor in device manager but that didnt work.
Specs:
