I got my ASUS 550Ti for christmas, upgrading from my Radeon HD 5450; uninstalling the AMD drivers via the install manager, and then installing nVidia drivers. My friend has a very much alike build to me, except for the motherboard (Mine is an AMD 760G, his is an nVidia 7025 chipset), but both boards with same specs. We both have the same processor (Athlon II x3) and PSU (Corsair CX430w), and we both upgraded from a 5450 to the ASUS 550Ti (This one: http://www.asus.com/Graphics_Cards/NVIDIA_Series/ENGTX550_TiDI1GD5/ ).
My problem is that I've been getting seemingly low FPS compared to him. I use a 1280x1024 monitor, and he has a 1920x1080 monitor. When playing MW3, I get around 40FPS at max settings, while he supposedly gets 60FPS at max settings.
I played Borderlands, BF3, Skyrim and DiRT 3 at nVidia's recommened settings, where I should be getting above 30FPS (BF3 should get ~45FPS, only gets ~30FPS. Borderlands should get ~70FPS, only gets about 45FPS. Skyrim should get ~45FPS, only gets around 30FPS, dropping to around 15FPS when near a river.)
This really doesn't make sense to me, and even less since benchmarking results (3DMark Vantage, 3DMark11 and FurMark 1.8.5) gives us both the same results.
I've managed to get fairly higher scores then him with these clocks: http://i54.tinypic.com/2l8dgys.png , but they don't make much difference in-game.
Could it be a hardware problem, or something software based? I've got the latest drivers from nVidia, and my BIOS is updated etc. I've tried the beta drivers, and also reinstalled the normal drivers twice with no difference made. We both use "Let Application Decide" in the 3D settings, but I can't see much of a change by setting it to "Performance". This is really bugging me, and I don't want to end up RMAing this GPU.
EDIT: After reinstalling the driver for the first time, I experienced worse problems, a further 10-15FPS drops in games, and Borderlands would only run between 5-15FPS. Fixed that with the 2nd driver reinstall.
