My XPS 720 has SLI 8800GTX nVidia cards so what cable do I need to connect to a 27 inch or 30 inch monitor to get the maximum native resolution of 2562x1440 or 2560x1600 since the output from my PC's cards are two DVI connections? My guess is a single cable with two DVI connections at the PC end and a single DVI connection at the monitor end but I am not sure that is correct. According to nVidia, my SLI 8800GTX cards will support these higher resolutions?
