Hello,
I'm new to building, but I've done tons of research over the past few weeks and am slowly gaining confidence. Individually, I think these parts are solid - I'm just not 100% if they will all work well together.
My wishlist on Newegg is:
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=23474847
or here are the details:
Antec Twelve Hundred V3 Black Steel ATX Full Tower Unbeatable Gaming Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129100
ASUS P8Z68-V PRO/GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131790
EVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support FPB Video ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130604
CORSAIR Professional Series Gold AX850 (CMPSU-850AX) 850W ATX12V v2.31 / EPS12V v2.92 80 PLUS GOLD Certified Modular Active ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139015
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Crucial M4 CT256M4SSD2 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148443
Rosewill RCR-IC001 40-in-1 USB 2.0 3.5" Internal Card Reader w/ USB Port / Extra Silver Face Plate
http://www.newegg.com/Product/Product.aspx?Item=N82E16820223103
G.SKILL Ripjaws X Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model F3-12800CL9Q-16GBXM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231478
LG Black Blu-ray Drive SATA Model UH12LS28 OEM LightScribe Support - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136232
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
Model #:GFC-02050
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
Extra facts:
No plans on overclocking just yet, maybe in the future
Plan to SLI another 560 ti in the future
May add sound card down the road if not satisfied with onboard audio
Games played: mostly Starcraft 2 and Diablo 3
Monitors: still deciding between dual 24s or dual 27s
Worries:Will I have all the cables I need, from the parts ordered (since the Blu ray drive is OEM, is there an extra SATA cable that comes with the mobo)?
Does everything work well together?
Should I get an anti-static wrist strap just to be safe, being a newbie?
Any important do's/don'ts of assembly greatly appreciated as well.
Also any advice on dual 24 vs dual 27 monitors appreciated (I feel like dual 27s might be overkill, and hard to play competitive SC2, but I could be wrong).
Thanks in advance!
Model #:GFC-02050
Extra facts:
Thanks in advance!
