Recently i bought new parts to build my own computer as a first timer and everything seemed to be going smoothly until the power up.I plugged my PSU in as the last step, flipped the PSU switch and hit the power button on my motherboard and got power on all my case fans and the leds on my mobo light up. The problem that im having is that my video card seems to be receiving no power, none of the fans on the GPU spin and im receiving no signal to my monitor.
What did i do wrong? Could i have gotten a defective GPU. Currently at work but im going to try to connect other PCI power cords to the card, maybe one of the power cords is defective, and if that wont work ill try installing my old video card and see if that generates anything.
Any other recommendations would be seriously welcomed.
(as a side note, im not getting any beeping and no blinking from my LED mobo lights but my CPU LED is red, according to the instructions it needs to be blinking for something to be problematic but since its not green i assumed that may be of help for the root of my problem. My back USB slots also dont seem to function on boot.)
Comp. Parts:
GIGABYTE GV-R695OC-1GD Radeon HD 6950 1GB 256-bit GDDR5 PCI Express 2.1 x16
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
ASUS P8P67 DELUXE (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Acer G235HAbd 23'' 5ms 1920x1080 WideScreen LCD monitor 300 cd/m2 1000:1
Intel Core i5-2500 Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 2000 BX80623I52500
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case
EDIT: There are 2 damn power supply connectors to the motherboard not just the 24 pin, works and everything runs perfectly. #Pluginfail
Comp. Parts:
