Solved
I need help, please read!
Okay, i am 15 and i am looking to buy a pc, preferrably homebuilt. I put together this last week a rig for $800, intel core i5, radeon 6870 GPU... Yeah.
My dad suggested i buy a prebuilt pc and upgrade the graphics card, which i thought was good idea until i found out it would cost me $200 or so, more. Actually around $250.
I told him i need to graphics card to play the newer games, and he is convinced mw3 and other games will play fine with no graphics card. He also thinks i don't need to upgrade from a 350watt power supply if i were to buy a new card on a prebuilt.
I don't know how to convince him to let me build my own, he says he hates building things like that, less complicated like a camers system. Any ideas?
Thanks
5 answers Last reply Best Answer
More about help read
  1. Building a system is not THAT hard, if you take the time to read up on what you are doing or watch videos, ask questions, etc, for things you have questions about. You will almost certainly get more bang for your buck if you go this route.
    You will need a GPU to play most new games with higher settings.
    Thanks, i thought that but he just doesn't understand it. His job is an electrician, i don't know why he is so opposed. I know you need an upgraded GPU :)
  3. Best answer
    If you end up not getting a GPU, you can always play Minesweeper. :D
  4. Best answer selected by aupad.
Homebuilt Graphics Cards Prebuilt Systems Systems
