Solved
Will my Radeon fit in this case?
Hi,
I have a Rosewill CHALLENGER-U3 case, and before I buy, I am wondering if my Radeon 6870 will fit in the case.
Thanks!
2 answers Last reply Best Answer
More about will radeon case
  1. Best answer
    Since you didn't mention which radeon 6870 (they can have different cooler lengths/slightly different widths) I will use this 6870 as an example:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814125357
    The cards dimensions:
    1.50"x 4.96" x 11.42" (W x H x D)
    Your case:
    http://www.rosewill.com/products/1807/ProductDetail_Specifications.htm
    Your case's dimensions:
    7.48” x 17.08”x 18.5” (W x H x D)
    Card + case:
    1.50"x 4.96" x 11.42" 6870
    7.48” x 17.08”x 18.5” case
    No problem. A 6870 will fit as long as it's not some strange mod.
  2. Best answer selected by CC Inc.
New Build Rosewill Cases Radeon Systems Product
