I have a power supply on a dell xps 600 thats whining even when powered down. it gets louder (or quieter sometimes) when on or under a load (basically just sounds like it speeds up sometimes fast enough not to sound so bad). I am probably going to replace the power supply soon (its proprietary and a pain) , but I have heard that this is possibly just a coil whine and can sometimes be simply fixed with some decent glue. And that coil whining doesnt necessarely mean theres a malfunction (atleast not a major one). I recently posted about replacing this and still hope to but I was just wondering if its possibly rebuildable? the fans both seem to be working fine. the whine continues when shutoff but if i pull the power plug it comes to a stop. then if i plug it back in it starts back up again (even if the computers off). It seems to go away after i leave it overnight but comes back when its on for a couple minutes.
Should i dismantle and try to repair? Is it something thats just annoying that wont cause a problem? Just wondering whether its failing and if it is, will it damage my computer to let it fail? I imagine thats always a possibility atleast with hard drive damage if its reading/writing during failure. But asside from that is my power supply gonna catch fire? explode? melt my mobo? should i not use it till i get another power supply and fix it? or like i said is it rebuildable so i can fix it? just wondering if anyone has had a similar issue and if its just a simple whine thats not hurting anything. hopefully i have it replaced soon but knowing i wont hurt anything makes me feel better about it..
any suggestions/comments greatly appreciated, thanks!
