Okay, I don't really use a front audio jack (my cheap speakers have a jack), but I had to urge to "fix" my front audio jack.
My NZXT Gamma case didn't have long enough front audio cables to reach to the back of my motherboard, so I needed to buy an extension. http://www.newegg.com/Product/Product.aspx?Item=N82E16812201025
The extension fit on the NZXT plug, as well as the Front AUdio pins on my motherboard. But there is still no audio using the front panel. Sound works fine through the speakers using my rear jack though. Ideas?
