New power supply
  • Power Supplies
  • Graphics Cards
  • Power
  • Components
  • Product
Last response: in Components
a b U Graphics card
June 17, 2012 1:29:12 PM
I am getting a new graphics card that requires two 6 pin power connectors, can i please get some advice on which PSU provides this at the lowest price
More about : power supply
a b ) Power supply
a b U Graphics card
June 17, 2012 1:35:18 PM
Antec and ocz are good values; some other brands are junk. Please list your new video card make and model.
a b ) Power supply
a b U Graphics card
June 17, 2012 1:35:45 PM
Hi :)
WHICH card ? and specs ?
All the best Brett :)
a b U Graphics card
June 17, 2012 1:37:59 PM
radeon hd 6870
a b ) Power supply
a b U Graphics card
June 17, 2012 1:39:58 PM
You'll be ok with a 500w antec or ocz if you don't overclock the cpu. Look for 35-40 amps on the 12v rail rating.
a b ) Power supply
a b U Graphics card
June 17, 2012 1:48:39 PM
It should work fine, but I wouldn't overclock with it. Antec might be better if you want to spend a little more.
