Sign-in / Sign-up
Dual monitor Problem
  • Nvidia
  • Dual Monitors
  • Graphics Cards
  • Displays
  • Graphics
Last response: in Graphics Cards
December 30, 2011 10:09:08 PM
Hello,
Hi i have installed dual monitors in win 7 32 bits and also extended the displays and is using a Male to Two HD15 VGA Female Cable
Connect a 59/60 pin graphics card connector to two monitors with HD15 connectors.
But i can only get the same picture on the dual monitors and can not send between.it only go out to the right and disappears.If i go far to the right i can drag it back again.Any idears on how to fix this problem
More about : dual monitor problem
a c 255 U Graphics card
a c 90 Î Nvidia
December 30, 2011 10:38:39 PM
What video cards or card are you using , is it AMD or Nvidia.
December 31, 2011 12:09:04 AM
Hi.
I am using NVIDIA GeForce 6600 GT
a c 224 U Graphics card
a b Î Nvidia
December 31, 2011 12:24:25 AM
Don't use that cable. You want two cables, one going to each monitor.
December 31, 2011 9:52:41 AM
Hi.
Ok.
Maybe a stupid question but is it so that i need one cable for the Avg and One for the DVI output then???
Brgds
Iceland
a b Î Nvidia
December 31, 2011 10:00:38 AM
If you mean one VGA and one DVI cable then correct. If that's how your monitors get a signal. Each monitor needs its own private cable going between it and the video card. When you use a splitter cable like you did then they end up sharing the same info.
December 31, 2011 10:10:13 AM
Hi.
Thank you for a quick answer.
I was actually thinking the same since The cable that i have has dimensions to fit the Vga output but i needed to be sure :??:  . so i guess it is out to purchase a DVI adaptor and cables then. ;)
Brgds
Iceland
