Solved
Corsair H100, G.skill Ripjaws X inside NZXT Phantom case question
  • G.SKILL
  • Cases
  • RAM
  • Cooling
  • Corsair
  • Components
Last response: in Components
June 18, 2012 2:39:15 AM
Hello,
I have an NZXT Phantom full tower case with G.skill ripjaws X RAM. I was planning on purchasing a Corsair H100 cooler for my i5 3750k but found out that installing that particular cooler might cause problems by coming in contact with the heatspreaders on the RAM. Can the H100 be installed inside the case and avoid coming in contact with the RAM, or should I get a different cooler? Thanks in advance.
More about : corsair h100 skill ripjaws inside nzxt phantom case question
Best solution
June 18, 2012 2:55:44 AM
No you can install it with that ram i know for sure have a friend who has same ram and H-100 no issues at all
June 18, 2012 2:58:21 AM
Awesome, thank you!
m
l
June 18, 2012 2:58:26 AM
Best answer selected by jcs331.
m
l
