Closed Solved
Power Supply and Video Card upgrade for Gateway DX4200-UB001A
Hello,
I am looking into buying a new video card and therefore a new power supply for my computer. I have a Gateway DX4200-UB001A and when I play MMOs, I lag even with low settings on graphics. I have a HD Monitor, what do you guys recommend for a budget of 200 for a video card?
6 answers Last reply Best Answer
More about power supply video card upgrade gateway dx4200 ub001a
  1. This will be a great improvement in your gaming experience.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814125401
    And a good brand 550W power supply will be more than enough. ( Corsair, Seasonic,Antec, OCZ,XFX )
  2. Best answer
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161384
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
    With rebates it will be around $180, and will give you nice gaming performance on your budget.
  3. Thank you guys!
    Refillable,
    Thank you for this also, now are these specifically for my computer? because I am about to order them but want to make sure these are right for my computer
  5. It will work for sure! I've checked your exact computer model online and I'm 100% it will work. Your motherboard has the required slot :)
  6. Best answer selected by perucho.
Graphics Cards Power Supplies Gateway Graphics Product
