Solved
Will the i7 3770 work with RAM clocked at 2133mhz?
Last response: in CPUs
June 18, 2012 5:16:27 AM
Intels website says it only works with 1333 and 1600 mhz, except i have been told otherwise?
a b à CPUs
June 18, 2012 7:36:32 AM
The i7 3770 should have no problems, as long as your Motherboard supports 2133Mhz memory.
m
l
June 18, 2012 8:04:20 AM
It is the Asrock z77 Extreme6, i assume that works, right?
m
l
a c 283 à CPUs
June 18, 2012 8:08:25 AM
Yes
From the product page on Newegg
Quote:
DDR3 2800+(OC)/2400(OC)/2133(OC)/1866(OC)/ 1600/1333/1066
It'll work just fine, albeit unnecessary. 1600 is plenty and you would never notice ANY difference in everyday usage and gaming between 1600 and 2133.
If you're shooting for high benchmark scores, go right ahead. It's a waste otherwise.
m
l
Best solution
a b à CPUs
June 18, 2012 9:16:11 AM
The i7 3770 + Asrock Z77 Extreme6 will run your 2133MHz memory just fine.
+1 ^
If you're planning to buy new memory, I too would recommend 1600MHz & save some bucks. :)
a b à CPUs
June 18, 2012 11:43:18 PM
Check this.
m
l
a b à CPUs
June 18, 2012 11:49:05 PM
If the RAM is great for OC and the mobo supports it and u know how to do it, its doable.
But the performance gain for most applications is next to nothing.
m
l
June 26, 2012 4:35:00 AM
Oh ok, so the performance gain is minimal, except its only $71, and i was spending about that much anyway, so i think i should go with it :)
m
l
June 26, 2012 4:35:37 AM
m
l
a b à CPUs
June 26, 2012 4:46:32 AM
m
l
June 26, 2012 6:49:15 AM
Its 1.5v! Thanks for your help!
m
l
June 27, 2012 12:25:30 AM
Best answer selected by XavierTobin.
m
l
