I have a Zalman 850 watt power supply, hooked up to a ATI Radeon 4890 X2.
The 4890X2 has a 6 pin connector and an 8 pin power connector.
The red led is lit on the D5 label on the back of the 4890, which from looking at the forums signifies not enough power, or a power issue.
The PSU is a component PSU and has fixed cables which have 2 x 8 pin PCI cables. I was thinking of grabbing a 6 to 8 pin adaptor cable and trying to use the component plugs on the PSU labelled PCI3, PCI4, and the other 6 to 6 PCI cable i have, therefore bypassing the fixed cables.
However am i wasting my time, since it comes from the same PSU, or will it be from a different part of the PSU, so may work?
I just want to test if it's a video card problem or a PSU problem. The system powers up ok, but doesn't boot.
Thanks
Thanks
