Sign-in / Sign-up
Building a pc - is this compatible?
  • New Build
  • Systems
Last response: in Systems
March 3, 2012 9:25:17 AM
Hi,
I am thinking about buying components and building a computer.
This computer is not a high end gaming pc, but a low/mid range gaming pc.
This is my first time building a pc.
Can anyone tell me if the following components are compatible:
Intel CPU Core i5 2500 Sandybridge LGA1155
Sony Optiarc 24X DVDRW SATA Black oem
Seagate 1TB hard disk drive SATA 32MB cache
TP-Link 300Mbps Wireless N PCI Adapter WN851ND
VTX3D 1GB Radeon HD 6870
CiT 750W Black PSU 12cm Dual 12v CE PFC Model 750UB
Gigabyte motherboard GA-Z68AP-D3 LGA1155
orsair memory 4GB XMS3 Kit (2x2GB) DDR3 1600MHz 240 pin DIMM Unbuffered
Case: ZALMAN Z9 Plus
If there is anything I need to change or upgrade, please reply.
More about : building compatible
March 3, 2012 9:47:39 AM
All is compatible. The only weak part in your build is the power supply.
Buy a 550W - 600W PSU from Antec,Corsair,Seasonic,XFX,OCZ,Enermax.
March 3, 2012 10:04:24 AM
Is 100% better than CiT.
