HELP WITH GRAPHICS CARD
Hey guys ,
Upgrading my video card and was wondering if i Could have some advice, I have around £170 to spend maximum!
I've been looking at a nvidia 560ti from either msi or asus though a more educated in terms of computing friend reccomends I use the 550 as the extra money isnt worth it. I usually run on a 32inch monitor at 1081p/ 1920*1080 res . Any other suggestions would help Thanks guys
7 answers Last reply
More about help graphics card
  1. personally i would go for this
    http://www.aria.co.uk/Products/Components/Graphics+Cards/NVIDIA/NVIDIA+GTX+560ti/Asus+GeForce+GTX+560Ti+DCII%2F2DI%2F1GD5+DirectCU+II+1024MB+GDDR5+PCI-Express+Graphics+Card+?productId=43564
    or the msi 560ti as a close second choice if you can find it for about the same price as the first card
  2. What is the rest of your computer - cpu, power supply... What games do you want to play?
    -Bruce
  3. what are you using the card for?
    if gaming the 560 ti is significantly better than the 550 ti.
    good point--i naturally assumed he would be gaming as he had a £170 budget
  5. Didn't I answer this already ? Feels like a double post....a bit iver ya budget if ya include VAT
    http://www.scan.co.uk/products/1gb-asus-gtx-560-ti-directcu-ii-top-40nm-4200mhz-gddr5-gpu-900mhz-shader-1800mhz-384-cores-plus-2-mo
  6. dont spend the extra 30 quid on the top version
    the normal version is only 70mhz lower and will overclock easily
Graphics Cards Graphics Product
