Hey, firstly, thanks for taking a look at my situation. First time builder, and first time poster, but hoping to get some help from some more technically minded folks. FYI: I'm planning on using this computer for gaming, but nothing too crazy. I don't care if I can't run a game on super high graphics. I'm just looking to be able to play most games, and have them look okay with a consistent framerate. I've got some parts picked out, and others I'm still going back and forth over. The one's where I only list one are pretty much definite, unless someone gives me a reason not to.
CPU: Intel i5-2400
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115074
Mobo: ASRock Z68 PRO3-M
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157252
RAM: CORSAIR XMS3 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233202
PSU: OCZ Technology Fatal1ty Series Modular 550 Watt ATX Power Supply
http://www.microcenter.com/single_product_results.phtml?product_id=0303417
Video Card: Either a radeon 6850 or 6870, haven't decided yet.
Case: Either a
HEC Blitz
http://www.newegg.com/Product/Product.aspx?Item=N82E16811121096
Or;
Cooler Master HAF 912
http://www.microcenter.com/single_product_results.phtml?product_id=0343331
And I already have a hard drive w/ an OS, in addition to an optical drive so I won't need either of those.
And so I'd really appreciate any help anybody can provide, in terms the stability of the parts, compatibility of the parts (I'm fairly certain everything works), and overall what the opinions of this build are. Again, any constructive feedback would be greatly appreciated. Thanks a lot in advance!
CPU: Intel i5-2400
Case: Either a
HEC Blitz
Or;
