My 560 Ti runs at 1440 rpm at idle and is at the lowest speed and it is too loud for me to sleep with it on. I contacted EVGA and told me that is the lowest it will go. In order to go silent I need some options. I was thinking to use sound-absorbing foam, but idk if it will do the job. My case is the CM HAF 922 and is a very open air case. I might be able to build some box thing around my computer to lower the sound, I don't know if this is a good idea. I believe the best thing to do is to either go with a silenced case or to get a quiet VGA cooler. I need some help about choosing the option that is the best way right now. I will be SLI'ng in 2-3 months and those aftermarket VGA coolers seem to use too much space. I found that if I use another 560 Ti with its stock cooling, I have 1/4" of clearance between it and my psu, idk if an aftermarket cooler will fit, unless there is one that will. Just need some help choosing an option here, thanks.
