Will these parts fit together
Will these parts Fit/work together?
Also, any suggestions for this gaming computer setup?
Asus 24xDVD±RW Serial ATA Internal OEM Drive DRW-24B1ST
Windows 7 Home Premium SP1 64bit
Antec One Hundred Computer Case
Corsair 4 GB DDR3 Laptop Memory
ASUS SABERTOOTH P67 LGA 1155 SATA 6Gbps and USB 3.0 Supported Intel P67 DDR3 1800 ATX Motherboard
OCZ ModXStream Pro 700W Modular High Performance Power Supply
Intel® - Core™ i5-650 3.2GHz Processor
EVGA GeForce GTX 550 Ti FPB 1024 MB
Western Digital Caviar Blue 500 GB SATA III 7200 RPM
3 answers Last reply
More about will parts together
  1. Laptop memory??? that probably wont fit
  2. Laptop memory will not work in that motherboard... you need desktop memory.
    That processor will not work with that motherboard, you need socket 1156, NOT 1155.
    Otherwise everything else is fine.
  3. There is no reason to buy the OCZ ModXStream Pro 700W over the 600W, as they have exactly the same cable configuration. The difference in the amount of power available on the 12V rails is not significant either (504W on the 600W vs 552W on the 700W).
    Personally I think the Asus Sabertooth P67 is not a particularly good/worthwhile board. Either get a different high end 1155 motherboard or save some money there and put that money into a better graphics card - as this is the most important part in a gaming computer.
    You don't really get anything from a high end motherboard as they are designed to support aggressive overclocking which is only possible with unlocked K-series CPUs, which are more expensive and not worth paying more for unless as like I said you should be focusing on the GPU first and foremost.
    Apart from that these days people should be buying 1155 hardware, as 1156 hardware is EOL.
    i3-2100 (or other members of the i3-2000 series) is the 1155 equivalent and shouldn't be significantly more expensive.
Prebuilt Systems
