Ok so I'm upgrading my netwok at home and thought I'd ask you guys your opinions. I have 2Meg ADSL which will (fingers crossed) be 24Meg ADSL2+ by the end of next year (hence not an all-in-one box solution), I also want to VPN into my network and also connect wirelessly.
Currently I have Buffalo WMR-54g which has been brilliant but it isn't a VPN tunnel terminator so my parents are getting it and I'm doing a complete upgrade.
I'm looking at a cheap 4port ADSL modem where the phone connection is. I have cabled the house with 3 ethernet ports to different rooms from here. I will connect these into the modem (leaving the other port for a possible HTPC in future). I will then connect a Linksys 4port VPN router (BEFVP41-UK) to the end of one of the ethernet cables upstairs which will give me an extra port or 2 near my desk so I can plug both my pc and my laptop into the wired LAN at the same time if needed. Finally I would connect a Linksys 54G AP (WAP54G-UK) into the VPN router to enable wireless acces throughout the house.
Firstly will this work ok? I have obviously set up and used wireless networks before but having all these boxes makes me wonder if there will be conflicts. Is it the best option giving me easier upgrade options in the future?
Secondly what are peoples experiances of these products?
Thanks in advance for the advice as always guys!
