Hello toms hardware community!
this is my first post on the forum so please address any mistakes i may have made.
I just built my very first home build computer and im having issues turning it on.
specs are:
a used (my old) emachines W3503 shell which has a 480W Antec Neo480 power supply
a new Biostar N68S3+ (which i got in a bundle with my CPU)
a new AMD Athlon II x3 triple core processor 3.3 GHz
a new Zotac Geforce GT 440
and a 250GB sata HDD
now this being my first build i do not know what the issue is
after everything has been connected and double checked i plugged in my power supply and tried to turn it on but no response.
i will state that before i switched out everything within the emachine it would do this periodically.
sometimes it would come on but no display, so i thought it was an issue with the old on-board video card but seeing as this is still an issue i would assume it is something else.
now ive had different responses from friends some say power supply issue, some say physical connections or the on/off button connection, others have told me that its more than likely my motherboard saying that it is "hit and miss" when you buy them. or that its an issue with the amount of ram to OS i have on there. (which i plan to change the OS to XP-64bit)
any information or direction i could i try will be greatly appreciated as i do not want to start sending stuff back if i have the means to correct the issue.
thank you very much any responses!
specs are:
