A ajgo333 Distinguished Mar 21, 2010 64 0 18,630 Mar 22, 2011 #1 is it possible to use a wireless router for making a wifi setup by connecting the router only to the broadband modem while the pc is kept switched off.if so which is the best bang for buck wireless router available now?
Solution Saga Lout Mar 22, 2011 It will work regardless of the computer and in fact will work without one at all once it's set up. Can't help on a recommendation though - my comments from the UK would be worthless in, say, the States.
Saga Lout Retired Mod Mar 31, 2010 24,042 310 69,740 Mar 22, 2011 Solution #2 It will work regardless of the computer and in fact will work without one at all once it's set up. Can't help on a recommendation though - my comments from the UK would be worthless in, say, the States. Upvote 0 Downvote Solution
A ajgo333 Distinguished Mar 21, 2010 64 0 18,630 Mar 30, 2011 #3 Saga Lout : It will work regardless of the computer and in fact will work without one at all once it's set up. Can't help on a recommendation though - my comments from the UK would be worthless in, say, the States. thanks for the answer Upvote 0 Downvote
A ajgo333 Distinguished Mar 21, 2010 64 0 18,630 Mar 30, 2011 #4 Best answer selected by ajgo333. Upvote 0 Downvote
