The only beef i have with that is that i have been logging my card and here are the records throughout me gaming/surfing/idling.
01/01/2012 21:26:06 Radeon HD 6800 Series: GPU temp:38C, PCP temp:0C, FAN:1055rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 21:30:11 Radeon HD 6800 Series: GPU temp:39C, PCP temp:0C, FAN:1054rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 21:31:06 Radeon HD 6800 Series: GPU temp:42C, PCP temp:0C, FAN:1050rpm, GPU load:0%, Vmem Usage:0%, GPU:900 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 21:35:11 Radeon HD 6800 Series: GPU temp:53C, PCP temp:0C, FAN:1263rpm, GPU load:0%, Vmem Usage:0%, GPU:900 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 21:36:06 Radeon HD 6800 Series: GPU temp:53C, PCP temp:0C, FAN:1267rpm, GPU load:28%, Vmem Usage:0%, GPU:900 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 21:40:11 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1213rpm, GPU load:18%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 21:41:06 Radeon HD 6800 Series: GPU temp:49C, PCP temp:0C, FAN:1190rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 21:45:11 Radeon HD 6800 Series: GPU temp:48C, PCP temp:0C, FAN:1191rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 21:46:06 Radeon HD 6800 Series: GPU temp:55C, PCP temp:0C, FAN:1336rpm, GPU load:32%, Vmem Usage:0%, GPU:900 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 21:50:11 Radeon HD 6800 Series: GPU temp:53C, PCP temp:0C, FAN:1265rpm, GPU load:0%, Vmem Usage:0%, GPU:900 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 21:51:06 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1227rpm, GPU load:16%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 21:55:11 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1248rpm, GPU load:7%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 21:56:06 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1247rpm, GPU load:0%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:00:11 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1278rpm, GPU load:47%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:01:06 Radeon HD 6800 Series: GPU temp:53C, PCP temp:0C, FAN:1275rpm, GPU load:22%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:05:11 Radeon HD 6800 Series: GPU temp:52C, PCP temp:0C, FAN:1245rpm, GPU load:0%, Vmem Usage:0%, GPU:900 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:06:06 Radeon HD 6800 Series: GPU temp:55C, PCP temp:0C, FAN:1410rpm, GPU load:40%, Vmem Usage:0%, GPU:900 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:10:11 Radeon HD 6800 Series: GPU temp:55C, PCP temp:0C, FAN:1410rpm, GPU load:26%, Vmem Usage:0%, GPU:900 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:11:06 Radeon HD 6800 Series: GPU temp:55C, PCP temp:0C, FAN:1415rpm, GPU load:24%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:15:11 Radeon HD 6800 Series: GPU temp:46C, PCP temp:0C, FAN:1150rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:15:48 Radeon HD 6800 Series: GPU temp:42C, PCP temp:0C, FAN:1074rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:16:06 Radeon HD 6800 Series: GPU temp:42C, PCP temp:0C, FAN:1072rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:20:11 Radeon HD 6800 Series: GPU temp:37C, PCP temp:0C, FAN:1063rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:20:48 Radeon HD 6800 Series: GPU temp:38C, PCP temp:0C, FAN:1064rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:21:06 Radeon HD 6800 Series: GPU temp:38C, PCP temp:0C, FAN:1061rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:24:21 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1061rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:25:11 Radeon HD 6800 Series: GPU temp:39C, PCP temp:0C, FAN:1057rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:25:48 Radeon HD 6800 Series: GPU temp:42C, PCP temp:0C, FAN:1058rpm, GPU load:43%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:26:06 Radeon HD 6800 Series: GPU temp:44C, PCP temp:0C, FAN:1057rpm, GPU load:39%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:29:21 Radeon HD 6800 Series: GPU temp:52C, PCP temp:0C, FAN:1268rpm, GPU load:0%, Vmem Usage:0%, GPU:900 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:30:11 Radeon HD 6800 Series: GPU temp:49C, PCP temp:0C, FAN:1185rpm, GPU load:0%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:30:48 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1237rpm, GPU load:0%, Vmem Usage:0%, GPU:900 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:31:06 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1213rpm, GPU load:11%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:34:21 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1213rpm, GPU load:14%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:35:11 Radeon HD 6800 Series: GPU temp:48C, PCP temp:0C, FAN:1186rpm, GPU load:0%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:35:48 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1189rpm, GPU load:37%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:36:06 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1216rpm, GPU load:0%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:39:21 Radeon HD 6800 Series: GPU temp:48C, PCP temp:0C, FAN:1175rpm, GPU load:48%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:40:11 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1166rpm, GPU load:35%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:40:48 Radeon HD 6800 Series: GPU temp:48C, PCP temp:0C, FAN:1190rpm, GPU load:44%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:41:06 Radeon HD 6800 Series: GPU temp:49C, PCP temp:0C, FAN:1193rpm, GPU load:9%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:44:21 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1202rpm, GPU load:13%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:45:11 Radeon HD 6800 Series: GPU temp:52C, PCP temp:0C, FAN:1244rpm, GPU load:0%, Vmem Usage:0%, GPU:900 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:45:48 Radeon HD 6800 Series: GPU temp:48C, PCP temp:0C, FAN:1216rpm, GPU load:0%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:46:06 Radeon HD 6800 Series: GPU temp:49C, PCP temp:0C, FAN:1197rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:49:21 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1217rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:50:11 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1218rpm, GPU load:16%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:50:48 Radeon HD 6800 Series: GPU temp:48C, PCP temp:0C, FAN:1219rpm, GPU load:38%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:51:06 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1217rpm, GPU load:11%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:54:21 Radeon HD 6800 Series: GPU temp:52C, PCP temp:0C, FAN:1224rpm, GPU load:16%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:55:11 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1219rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:55:48 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1220rpm, GPU load:35%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 22:56:06 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1247rpm, GPU load:15%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 22:59:21 Radeon HD 6800 Series: GPU temp:49C, PCP temp:0C, FAN:1221rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:00:11 Radeon HD 6800 Series: GPU temp:49C, PCP temp:0C, FAN:1193rpm, GPU load:0%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:00:48 Radeon HD 6800 Series: GPU temp:49C, PCP temp:0C, FAN:1166rpm, GPU load:8%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:01:06 Radeon HD 6800 Series: GPU temp:48C, PCP temp:0C, FAN:1194rpm, GPU load:22%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:04:21 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1247rpm, GPU load:20%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:05:11 Radeon HD 6800 Series: GPU temp:48C, PCP temp:0C, FAN:1155rpm, GPU load:1%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:05:48 Radeon HD 6800 Series: GPU temp:43C, PCP temp:0C, FAN:1069rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:06:06 Radeon HD 6800 Series: GPU temp:42C, PCP temp:0C, FAN:1070rpm, GPU load:4%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:09:21 Radeon HD 6800 Series: GPU temp:39C, PCP temp:0C, FAN:1068rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:10:11 Radeon HD 6800 Series: GPU temp:39C, PCP temp:0C, FAN:1065rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:10:48 Radeon HD 6800 Series: GPU temp:39C, PCP temp:0C, FAN:1062rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:11:06 Radeon HD 6800 Series: GPU temp:39C, PCP temp:0C, FAN:1066rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:14:21 Radeon HD 6800 Series: GPU temp:38C, PCP temp:0C, FAN:1062rpm, GPU load:3%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:15:11 Radeon HD 6800 Series: GPU temp:39C, PCP temp:0C, FAN:1064rpm, GPU load:2%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:15:14 Radeon HD 6800 Series: GPU temp:39C, PCP temp:0C, FAN:1063rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:15:48 Radeon HD 6800 Series: GPU temp:45C, PCP temp:0C, FAN:1060rpm, GPU load:41%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:16:06 Radeon HD 6800 Series: GPU temp:45C, PCP temp:0C, FAN:1059rpm, GPU load:36%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:19:21 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1212rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:20:11 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1241rpm, GPU load:37%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:20:14 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1245rpm, GPU load:0%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:20:48 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1191rpm, GPU load:3%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:21:06 Radeon HD 6800 Series: GPU temp:49C, PCP temp:0C, FAN:1242rpm, GPU load:0%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:24:21 Radeon HD 6800 Series: GPU temp:52C, PCP temp:0C, FAN:1243rpm, GPU load:14%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:25:11 Radeon HD 6800 Series: GPU temp:49C, PCP temp:0C, FAN:1245rpm, GPU load:0%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:25:14 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1191rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:25:48 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1228rpm, GPU load:30%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:26:06 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1218rpm, GPU load:44%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:29:21 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1212rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:30:11 Radeon HD 6800 Series: GPU temp:49C, PCP temp:0C, FAN:1193rpm, GPU load:46%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:30:14 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1219rpm, GPU load:13%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:30:48 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1222rpm, GPU load:15%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:31:06 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1220rpm, GPU load:18%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:34:21 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1248rpm, GPU load:14%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:35:11 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1222rpm, GPU load:6%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:35:14 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1220rpm, GPU load:20%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:35:48 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1267rpm, GPU load:8%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:36:06 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1250rpm, GPU load:37%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:39:21 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1071rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:40:11 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1070rpm, GPU load:1%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:40:14 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1071rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:40:48 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1068rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:41:06 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1069rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:44:21 Radeon HD 6800 Series: GPU temp:45C, PCP temp:0C, FAN:1082rpm, GPU load:38%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:45:11 Radeon HD 6800 Series: GPU temp:47C, PCP temp:0C, FAN:1124rpm, GPU load:40%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:45:14 Radeon HD 6800 Series: GPU temp:48C, PCP temp:0C, FAN:1141rpm, GPU load:24%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:45:48 Radeon HD 6800 Series: GPU temp:49C, PCP temp:0C, FAN:1162rpm, GPU load:0%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:46:06 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1217rpm, GPU load:21%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:49:21 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1275rpm, GPU load:12%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:50:11 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1274rpm, GPU load:19%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:50:14 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1240rpm, GPU load:39%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:50:48 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1248rpm, GPU load:0%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:51:06 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1194rpm, GPU load:17%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:54:21 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1278rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:55:11 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1248rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
01/01/2012 23:55:14 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1252rpm, GPU load:0%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:55:48 Radeon HD 6800 Series: GPU temp:53C, PCP temp:0C, FAN:1278rpm, GPU load:24%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:56:06 Radeon HD 6800 Series: GPU temp:52C, PCP temp:0C, FAN:1249rpm, GPU load:23%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
01/01/2012 23:59:21 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1277rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:00:11 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1224rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:00:14 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1220rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:00:48 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1248rpm, GPU load:19%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 00:01:06 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1197rpm, GPU load:11%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 00:04:21 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1246rpm, GPU load:0%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 00:05:11 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1251rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:05:14 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1250rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:05:49 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1252rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:06:06 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1224rpm, GPU load:24%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 00:09:21 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1222rpm, GPU load:17%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 00:10:11 Radeon HD 6800 Series: GPU temp:53C, PCP temp:0C, FAN:1271rpm, GPU load:24%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 00:10:14 Radeon HD 6800 Series: GPU temp:52C, PCP temp:0C, FAN:1279rpm, GPU load:14%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 00:10:49 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1281rpm, GPU load:19%, Vmem Usage:0%, GPU:775 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 00:11:06 Radeon HD 6800 Series: GPU temp:50C, PCP temp:0C, FAN:1225rpm, GPU load:44%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:14:21 Radeon HD 6800 Series: GPU temp:41C, PCP temp:0C, FAN:1074rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:15:11 Radeon HD 6800 Series: GPU temp:45C, PCP temp:0C, FAN:1092rpm, GPU load:1%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 00:15:14 Radeon HD 6800 Series: GPU temp:46C, PCP temp:0C, FAN:1088rpm, GPU load:2%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 00:15:49 Radeon HD 6800 Series: GPU temp:42C, PCP temp:0C, FAN:1072rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:16:06 Radeon HD 6800 Series: GPU temp:41C, PCP temp:0C, FAN:1069rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:21:09 Radeon HD 6800 Series: GPU temp:41C, PCP temp:0C, FAN:1069rpm, GPU load:8%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:21:34 Radeon HD 6800 Series: GPU temp:45C, PCP temp:0C, FAN:1076rpm, GPU load:0%, Vmem Usage:0%, GPU:900 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 00:26:09 Radeon HD 6800 Series: GPU temp:39C, PCP temp:0C, FAN:1066rpm, GPU load:3%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:26:34 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1065rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:31:09 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1067rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:31:34 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1064rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:36:09 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1065rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:36:34 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1066rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:40:47 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1066rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:46:18 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1063rpm, GPU load:6%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:51:18 Radeon HD 6800 Series: GPU temp:39C, PCP temp:0C, FAN:1064rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 00:57:09 Radeon HD 6800 Series: GPU temp:45C, PCP temp:0C, FAN:1087rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 01:00:31 Radeon HD 6800 Series: GPU temp:42C, PCP temp:0C, FAN:1072rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 01:02:09 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1068rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 01:11:44 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1061rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 01:16:44 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1066rpm, GPU load:1%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 01:21:44 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1068rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 01:26:44 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1067rpm, GPU load:1%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 01:31:44 Radeon HD 6800 Series: GPU temp:40C, PCP temp:0C, FAN:1068rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 01:36:44 Radeon HD 6800 Series: GPU temp:44C, PCP temp:0C, FAN:1086rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
02/01/2012 01:41:44 Radeon HD 6800 Series: GPU temp:47C, PCP temp:0C, FAN:1169rpm, GPU load:1%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 01:46:44 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1196rpm, GPU load:1%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 01:51:44 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1253rpm, GPU load:1%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 01:56:44 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1273rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 02:01:44 Radeon HD 6800 Series: GPU temp:51C, PCP temp:0C, FAN:1257rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 02:06:44 Radeon HD 6800 Series: GPU temp:52C, PCP temp:0C, FAN:1286rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:1050 MHz
02/01/2012 12:14:21 Radeon HD 6800 Series: GPU temp:38C, PCP temp:0C, FAN:1041rpm, GPU load:0%, Vmem Usage:0%, GPU:300 MHz, Shader:0 MHz, Memory:300 MHz
